跳转到主内容
加入维修社区 - 创建账户
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Washer won't enter rinse cycle.
My Kenmore 110 washing machine fills, agitates and spins fine. However, when it gets to the Rinse step, it does not fill and only buzzes. Adjusting the knob slightly forward does nothing. I can advance it to the next spin step and it works. I can advance it to a new cycle and it fills fine. Lid sensor is ok, water supply and drain are fine.
I cannot find any mention of drain filters (wondering if they are clogged) in the manual. Before I call someone or take apart the dial, any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @krisf,
What is the model number of the washer?
完成的
添加一条评论
1个答案
Clogged drain filters, if present, would stop it from draining, not filling. If it fills on a wash cycle and washes, but not a rinse cycle, then the water supply & valves and the lid sensor are fine. Are there any other rinse cycles that it fills on? Can you determine where the buzzing is coming from? If it is the water valve, then there is a problem with your controller since they work for washing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kris F 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 32
总计 385
