does not crank or start
I have a 2013 1.3 chev utility. After testing glow plugs(due to black smoke when accelerating) it started, took it for short drive and parked it. When i wanted to start it again does not crank or start but dash lights are on. Also don't hear the fuel pump coming on. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
@shauncloete give us a better description of the model of this Chevy Not sure what model a 1.3 Utility is. If anything it sounds like some sort of rebranded import.
完成的
@oldturkey03
Best I can find out about the Chev 1.3D utility is that it is in South Africa and it has a Fiat engine.
Doesn't help with the crank/ignition problem I know. Can't find a repair, wiring or even an owner manual for it ;-)
Cheers
完成的
@jayeff what an oddity :-)
完成的
添加一条评论
