跳转到主内容
一个广泛的电子产品维修指南,从家和汽车音响到计算器。
26406 个问题 查看全部
LED backlight, for the LCD display on any mobile iDevice.
After obtaining a large amount of broken LCD displays for iPads and iPhones, I have stripped them down, and have removed the LED back light arrays from the LCD displays. Does anyone have any idea how the iPhones or iPads power these LED array, as I can only manage to light up a single LED at a time, by giving power to that one specifically. Any help would be great as I would like to power the whole array in some mini projects, and I'm just having no luck at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Conan, take a look on here and follow the links that are left in the comment by jseraphim. Pretty good description of the actual circuit. The only other thing I would do is to look at the available iPhone circuit diagram and layout and see where to light up the LCD.
这个答案有帮助吗?
得分 1
3条评论:
Thank you for the schematics oldturkey, I'll try and utilise these to find how to power solely the LED arrays without having them attached to a device.
完成的
Conan, if you need the circuit diagram for the iPhones, email me. My address is in my profile.
完成的
Thanks for the help turkey, the info you gave me was useful but, unfortunately, I didn't manage to solve my problem with the powering issue for the LED arrays, but they were very interesting to trawl through. Thanks.
完成的
添加一条评论
You need to ask ten different people and , sum of the group.you can come up with the best answer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Conan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,507
