跳转到主内容
My computer electronics won't turn on when I power them on
When I connect my PC to the electronics line, the LED bulb on the motherboard lights up, but no fan turns on, the display does not come on, the mouse does not work, the keyboard does not work. When I connect my PC to the electronics line, the LED bulb on the motherboard lights up, but no fan turns on, the display does not come on, the mouse does not work, the keyboard does not work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
In general, when this happens, it means that there is a connection in the CPU phase circuit and the problem will be solved by removing the connection. Of course, make sure the CPU is healthy in advance. > With a multimeter, you will notice that all 4 pins are connected to each other, which should not be the case. Check the CPU phase input MOSFETs and replace the faulty part to solve the problem.
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like a power issue. Had a similar thing once and it turned out to be a faulty PSU (Power Supply Unit). Might want to check yours or maybe try with a different one if you have a spare.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ABR41 Riad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 138
