跳转到主内容
加入维修社区 - 创建账户
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Won't turn on
My laptop won't get turns on when I plugged in charger or plugged out. Even no indicating light turned on. When I press power button, don't get any response from the laptop.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is a harder issue to solve. Try a different power supply for the laptop. If that didnt work, unplug the battery. A battery can short circut and cause the laptop to not do anything. You should be able to find a guide that shows you how to open up the laptop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rubaiyat Hiya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 129
