跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Mic won't work when I put it on speaker
I just replaced my messed up chassis of my 4s and I took apart the phone phone and I put it back together. Now I don't know why everything works fine but the mic only works when I hold the phone up to my ear but not in speaker phone. I was wondering why
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The Speaker assembly (the part that emits volume when the "speaker phone" function is enabled) also acts as a microphone.
Although there are already two microphones throughout the iPhone (one at the top beside the headphone jack and the other on the bottom Left of the iPhone) the Speaker assembly has a duo function and will act as a third microphone to pick up more volume when the iPhone is further away from your mouth.
Sounds to me as though your Speaker Assembly is faulty and you will need to install a new one :( I Hope this helps!
Martin
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jose l carreon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 2,188
