跳转到主内容
The Apple TV is a digital media receiver designed by Apple and released on March 21, 2007
17 个问题 查看全部
问题已关闭
Flashing Orange light on Power-Up
Hi, Can anybody suggest an alternative remedy. I replaced the hard drive on my 1st gen Apple TV as I was told it would almost certainly the hard drive. After ordering one and fitting it, I still have the orange flashing light.!!!
Any other ideas what it might be ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
1. unplug unit
2. after 1 minute plug back in and hold the menu and button for 3 seconds.
(unit should reboot and go into recovery mode)
3. In recovery mode, run diagnostics and if passed then perform factory resotre.
4. Problem should be resolved - resync with iTunes, run updates
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
2条评论:
Thanks Machead3. I've tried that but it is still flashing orange.
完成的
Two reported causes: - failed apple update, failed logic board. You know if you did the update. . . if you can put the HD in an external case or different machine you might be able to wipe the drive and start over. Good Luck,
完成的
添加一条评论
This might help, worked for me:
I opened up the Apple TV and popped out the Button-Cell battery for about 10-15 seconds. Verified it still had a 3V charge, and replaced it. Booted back up and after 10 seconds, held down the Menu and - button to get to diagnostics and it worked. Said nothing wrong and continued booting. Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
Just an addition... I tried this and it didn't work. However, I was using a Logitech Harmony remote. Since it operated the Apple TV just fine, I figured it would work for the reboot process. It didn't. However, when I dug up the Apple remote it then worked and now my Apple TV is fine.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 14,792
