跳转到主内容
Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
520 个问题 查看全部
Microsoft cooling pad messing with the Superdrive: is that possible?
I've just fixed together my Macbook. The Superdrive was acting up, and the case was bulging. So I redid every connection, fixed every nook and cranny and it seems to go just fine. At least without cooling pads.
Then I put my Core due on a Cooling Pad, this one, to be precise.
http://www.amazon.com/Microsoft-Z3C-0000...
When I put it with the two gummy pads, the ones matte colored in the picture, on the longest parts of the bottom case (running under the trackpad and the display) the Superdrive works just fine.
When I put it sideways, with the gummy pads under the superdrive and under the bezel with the Firewire, USB and audio ports, the Superdrive acts up like when it was misaligned, and spits every CD or DVD I give it.
With a completely flat cooling pad, it works fine. On the desk, it works fine. Sideways on the Cooling Pad microsoft, even on my knees, it spits the DVD out. Fitted with the gummy parts under the display and the pad, it works, even on uneven surfaces.
What's happening?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Android 维修工具包
A new screen or battery is one kit away.
现在开始购物
Android 维修工具包
现在开始购物
1个答案
已选择的解决方案
Sound like lower case deforms when it has uneven support. Solution=don't use it like that.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
按维修分数 3
评论:
Another solution: I'll find a better cooling pad.
Thank you.
添加一条评论
添加你的答案
Stefano Gigante 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 555
