跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
135 个问题 查看全部
MacBook won't turn on even after battery replacement
Hey,
I recently tried to power my older MacBook Pro mid 2019 (4 TB ports + TouchBar) after not using it for several months (about half year). First, it powered on after plugging it into power and booted into MacOS even though it showed 0% battery. I let it keep charging for several hours and when I came back and tried to wake it up it did not react. Since then, it won't power on, despite trying SMC and PRAM resets and everything as described by the apple support website.
My guess was the battery which might suffer from deep discharge and needs replacement (even though the laptop is from 2019 it was heavily used throughout the years and battery had over 1k cycles). So I ordered a replacement kit from iFixit and replaced the battery. Everything went fine during replacement. But still, even with the new battery the MacBook won't start.
Is there any chance that it's not the logic board, but instead any software issue? What are your guesses, any recommendations on what else to try?
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you see the battery icon on the screen? Do you have access to a USB-C power meter which you can monitor the power adapter power to the system. I would also try a second charger and cable and try the other ports as well.
Let us know what you discover
这个答案有帮助吗?
得分 0
3条评论:
Hey Dan,
Thanks for your reply. I don't have access to a USB-C power meter, but the power adapter works for my other MacBook. I also tried another cable and power adapter from my newer MacBook that I use regularly. I tried all 4 ports of the MacBook. The battery icon does not appear on the screen.
But when I move my fingers over the chassis while plugged in to power supply, I feel this slight vibration which is typical for a loading Macbook (have the same feeling for my new MacBook as well). So, I assume that power supply is not the issue.
I also tried to run the MacBook with deconnected battery - doesn't work either.
完成的
@yocz7zqetdup5lx - This series had an issue with the power switching logic. From the sounds of it this will need someone with deeper skills as one needs the proper tools to diagnose the logic board as well as micro soldering tools and skills to replace the defective chip.
完成的
Oh crap. Okay, I already gave up all my hopes to get this little beast running again. Luckily, data was all backed up. Still, a very expensive paperweight ;D
Thx for your ideas! If someone of you knows a guy with too much time, skill and tools to get it running again who lives in northern Germany, please let me know ;-)
完成的
添加一条评论
添加你的答案
F M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 113
