跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
798 个问题 查看全部
I replaced the screen but the click wheel isn't working.
The screen on my 5th Generation I-pod Video was cracked. I followed the instructions and replaced the front cover and screen. The click wheel worked before the repair and I did not do anything with the click wheel during the repair. Now, the click wheel does not work except I can hold down the select middle button and menu and reset my i-pod all day long. Any assistance would greatly be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Make sure after the repair you connected anything you unconnected during the repair.
这个答案有帮助吗?
得分 1
1条评论:
I reopened and made sure everything is reconnected. Everything is back where it is supposed to be, but the click wheel is still doing the same thing as I wrote above. Any other ideas?
完成的
添加一条评论
I have the same problem. I've pulled apart again and can find anything amiss. I've done a restore and that didnt change anything either. The restart works (holding the menu and center button)so the buttons are connecting to something, but I cant get a response beyond that.
Please help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dragonlore 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,026
