跳转到主内容
索尼 PlayStation 5 DualSense 手柄的维修文档。 型号: CFI-ZCT1W FCC ID: AK8CFIZCT1
83 个问题 查看全部
Why is my anolog replacement never central
Hi all
First time asking a question on here so here it goes.
I've recently come across a broken controller that I'm repairing. The issue is stick drift and I've decided to change the anolog and re solder a new one on. Everything has gone great and the repair was a success. However, whenever I tested it on Gamepad Tester and the anolog is not central. It's always rather 0.4 to the left or right.
Is there a way to get the anolog closes to the centre as possible or is this impossible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Usually you cannot get the analog completely centered. It will always drift a bit to some direction. Even the "professional" controllers have it same. If the 0.4 drift doesn't affect gameplay in any way or register as movement, it's completely normal.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Most of them have potentiometers on them, so that you can adjust the thumbstick itself. If you can't center it that way, you can try adding a resister to the board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Brooks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 29
