跳转到主内容
加入维修社区 - 创建账户
丰田于 2001 年 9 月发布了 2002-2006 年款的 Camry XV30 系列,将其作为一款体型更大的轿车。
My trunk won't open from the driver side
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @donlee80811, do you mean that the lever by the driver's seat doesn't pop the trunk as it should? If this is the case, then the cable that connects the lever to the trunk latch has probably stretched. It may also have snapped/dislodged. This happens gradually over the years with cable latches, and you can usually fix it by adjusting the cable tension.
In to diagnose the issue, have someone sit in the driver's seat and pull the lever repeatedly. Then go around to the trunk and listen for the mechanism inside:
  • If you hear it working, then the cable has stretched and needs to be re-tensioned.
  • If not, the cable has probably snapped or dislodged from the latch mechanism. Watch this YouTube guide on how to replace it here
Give this a try and report back, we'll go from there
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Donlee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 44
总计 825
