跳转到主内容
加入维修社区 - 创建账户
HP Compaq 8200 Elite 是一款小型工作站级台式电脑,面向高端办公和设计工作。它的设计相当易于维修,重点在于让技术人员能够快速更换驱动器和板卡。
My PC beeps and won't start
When I start my PC it's not working and beep sound is coming and not starting any solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
2条评论
Yes beep sound coming and not starting
由完成的
انا عندي 5 رنات و يتوقف وتم التاكد من الرامات و شغاله و غيرت الباور صبلاي و برضو المشكله موجوده
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @einsteinl
Count the number of beeps that you hear.
There will be a pause between the series of beeps and then it will start the beeps again e.g. 4 beeps > pause > 4 beeps > pause or 2 beeps > pause > 2 beeps > pause etc.
This is a fault code and the number of beeps will tell you what's wrong.
This page of the hardware maintenance manual details beep codes 1-4, the next two pages cover beep codes 5-11.
这个答案有帮助吗?
得分 12
4条评论:
@einsteinl
Try either reseating the memory modules or testing if each one is OK.
Reseating the memory means removing the memory modules and then reinserting them.
If that doesn't work, if there is more than 1 memory module installed, remove all the modules except 1 and then see if it turns on OK.
if not remove that module and try the next one - you may have a faulty memory module.
The manual I linked shows how to remove/replace the memory modules
IMPORTANT!!
ALWAYS turn off the PC and DISCONNECT THE POWER from the PC BEFORE removing/replacing any memory modules. Once you have finished removing or replacing a module, only then reconnect the power to the PC and turn it on.
Removing memory modules with the power still connected, even if the PC is off is a good way to cause damage to them or other components on the motherboard
由完成的
I cleaned the rams and then it started
由完成的
I tried it and it doesn't work, noting that the alarm counts 9 times and then stops, and so on.
由完成的
انا عندي5 رنات ثم يتوقف
由完成的
添加一条评论
添加你的答案
Einstein l 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 61
总计 3,288
