跳转到主内容
Repair and disassembly guides for Acer TravelMate laptops.
33 个问题 查看全部
Yellowish cycle in the middle of ACER laptop's screen
Laptop ACER Travelmate 4000LMi
Before few days i noticed a yellowish oval shaped area in the middle of my screen. This area can be shown, better, in a white page (picture 1) and even more clearly if look from an angle from above were, because of the angle of view, the white area turns darker (picture 2).
picture 1
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It's difficult to say for sure from your photos, (I know this kind of thing is really hard to capture in pictures from experience) but it's possible this is a sort of screen damage. It's something I see usually in laptops with plastic or more flexible housings.
If something was set on top of the laptop with the lid closed, or it was carried in a bag with other items, then the display may have sustained some damage from the pressure.
It's unfortunate, but in my experience display malfunction of some kind is the only thing that causes this and you'll likely need a new display to resolve it.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for help.
I will try to disassemble it to see if there is something like moisture or like that, from inside. The last time i disassemble it, there was a problem on the bottom side of the plastic frame. It does not close 100%. Maybe the liquid i clean the screen (it is a special liquid for screens) passed through this opening. Or moisture.
Hope do not need replacement...
完成的
添加一条评论
添加你的答案
krakadoros 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 44
