跳转到主内容
Why is the traction control light always on?
https://www.reddit.com/r/BMW/comments/1q...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Always? Is it a new car to you or did you just notice?
完成的
添加一条评论
1个答案
Try pushing the button on your dash or beside your shift stick that says esc , stands for electronic skid or slide control. The light means someone at some point pushed button wondering what it was or so they could actually drive like an m series should be driven but forgot to switch it back after. If it stays on after that a sensor for your esc got dirty or shifted when in manual mode. Try washing under car or just go who needs esc im the one in control and put up with lil light on dash. Worst case scenario is your esc unit is toast and either replace it or refer to my earlier remedy of not having traction control.
I’m pretty confident one of these very simple to test theories will be what turns off your light.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mayssam Hassoun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 26
