马自达汽车的修理和支持指南。
209 个问题 查看全部
1985 Mazda glc axle removal
how do I remove the drivers side axle from the transmission on a 1985 mazda glc
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Woodwiz,
In general:
Take the wheel off, unbolt the main bolt on the hub and turn aside the rotor. You may need to unbolt the steering knuckle ball joint, the brake caliper, and the strut assembly also to make room for the rotor and hub to turn out of the way of the axle spline
Pull the other end of the spline out of the transmission and you have removed your half shaft.
For a more detailed explanation with photos, check this link.
All front wheel drive cars are more or less the same procedure.
Please let us know how it goes.
Frank
这个答案有帮助吗?
按维修分数 2
评论:
Just like 040304 mentions, here is the what you would do it in order to remove the drive shafts "
Remove the front wheels.
Disconnect the lower ball joints from the steering knuckles.
Pull the driveshafts from the differential gears. A circlip is positioned on the driveshaft ends and engages in a groove, machined in the differential side gears. The driveshafts may have to be forced from the differential housing to release the clip from the groove. Do not apply a sharp impact. Do not allow the driveshaft's free end to drop, otherwise may occur to the ball and socket joints as well as to the rubber boots."
添加一条评论
添加你的答案
woodwizard59 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 465
