跳转到主内容
加入维修社区 - 创建账户
Steam Deck 是 Valve 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
Steam Button and "..." Button don't work
Steamdeck received some water, it was open following guides from here for clean-up. After reassembling it, it works fine except for the Steam and "..." buttons. Both don't work as expected, instead they enable the cursor and slightly move it to the left when clicked. Also the right stick is failing on the X axis but that is easily replaceable. Do you think there is a way to fix the Steam and "..." buttons or should I consider my console dead?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I suggest you open a RMA request, if you have the technical knowledge to disassemble the console you can go ahead and open it, give it a good clean with IPA and reassemble it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lucas Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 207
