I have an laptop hp probook 8th, it doesn't open … When I connect the
I have an laptop hp probook 8th, it doesn't open … When I connect the charger, it flashes in two colors white and yellow, and caps look press switch illuminates and turns off
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
c). Remove the RTC battery from the motherboard.
Here’s the maintenance and service guide for the laptop. Go to p.35 and p.73 90 to view the necessary pre-requisite steps and then the procedure to remove the main battery and the RTC battery, respectively. Unfortunately with your model you will have to remove the motherboard to access the RTC battery.
When the RTC battery is removed measure its voltage. If it is <2.6V DC replace it. The part number is L23943-001. Search online using the part number only, to find suppliers of the part.
d.) Reconnect the RTC battery (or its replacement).
e). Reverse the above steps to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 68
2条评论
Hi @mhmdlfth70816,
Please confirm the model number of the laptop as shown on the product label on the bottom of the laptop?
由 jayeff 完成的
@jayeff
Holla 🙏
Hp probook 640 G4 -ProdID 2GL98AV
由 محمد الفاتح 完成的
