联想笔记本电脑的维修和支持指南。
941 个问题 查看全部
Thinkpad BIOS password reset questions
Thinkpad BIOS passwords are tricky things. I recall them not being dependent on a simple removal of a small CMOS battery but stored in some sort of special thing, it's been awhile since i had to look into this.... however on a model as old as what i am working on not sure if that is applicable or not.
I am looking for some direction or info about how to reset the BIOS password on this X40 Thinkpad i have. ( no machine type# on the bottom)
I would rather try and make use of it and fix it up, couple of other things it needs, and a small laptop would be mine to use..... rather then giving it away for parts or something.
Any input would help, if simply pulling the CMOS battery solves the problem on a model this old then i would be happy to hear that.
Or some kind of Linux tool.
Or if i am just out of luck.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
评论:
Please tell us more about this machine and which password you are wanting to remove/recover. Does the machine boot? Can you get to the OPSYS or a prompt? There is the actual BIOS password that lets you change setting in the CMOS/BIOS.. There is also the power on password, the supervisor password and the hard drive password. Are you locked out of the system or the BIOS?
Its a BIOS supervisor password. No system access... Complelty locked out... No HD.... I was aware of the workaround but seemed like a significant amount of work for a laptop of this age, for a newer model yes....... I didn't know about being able to buy a new chip and solder it in. Something i will have to consider with the laptops current condition ( no hard drive, bad battery). im going to try and vote your comment up to an answer...
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
Click here for the work around. Click here to purchase a new password storage chip for your laptop. Replacing the chip will solve your problem, it cost a bit more than the work around, but is an easier fix. The fore mentioned solutions are for the Supervisor password, which is the hard one. There are jumper pads in the RAM compartment to reset the power on password.
这个答案有帮助吗?
按维修分数 2
评论:
Click here For a better price than the original price I gave you. I have not checked Mouser or Newark for availability. This is/was a fairly common chip. At one time it was even found on some sticks or RAM, might still be - I don't know. Thank you for accepting my answer. Good luck with the laptop. I have a couple of T42s to put together.
Warning: First link leads to a weird ad-site only.
添加一条评论
I find an article about how to reset BIOS password on Windows laptop, you can read it in:
http://www.recoverlostpassword.com/artic...
这个答案有帮助吗?
按维修分数 0
添加一条评论
I also have X240, I can enter to bios setup but cannot config any thing. so I think It has supervisor password .
please help!!!!
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 43
过去的30天: 160
总计 17,226
