charger doesn't change from orange to green
hi, I've got my sons g4 a1134 plugged in to charge,yet now I've had the charger plugged in for the last 24 hours and the charging indicator won't change from amber to green. i try turning on the computer, yet nothing works.no sound,picture or a simple beep. what could it be?
please help?
Update
i havent touched it at all. I've had it packed away for a little, and pulled it out the other day and put the charge on it for about 10 minutes then tried to turn it on but still nothing. i left the charger overnight and noticed the chargers light didn't change from orange to green.just stayed orange and still is orange if i turn the charger on. nothing was spilt on it, or done any type of work on it.
Hey Nick, could you give us a little bit more information to help diagnose your problem? When did it stop turning on? Was anything spilled on it? Did it make any weird noises? Have you taken it apart at all?
由 Jake Devincenzi 完成的
Have you tried an SMC reset yet?
由 David Hodson 完成的
I've pulled out the battery and its still amber. i will leave the battery out and unplugged overnight and see it again tomorrow. if it still dent work it must be the dc board as the charger works fine on my cousins laptop. thanks for the help and ill keep you in touch.
by the way, whats a SMC reset? should i give that a go as well?
由 nick 完成的
hi again
i just received my new dc in board and changed it. i had tried it and yet still nothing. no sound, no picture just silence. i had pulled out the battery and let it rest with computer for 24 hours and put it all together today, yet still nothing. is it for the bin or should i try something else?
由 nick 完成的
