跳转到主内容
Business-grade laptop released in 2009. Model Number: Latitude E5500.
15 个问题 查看全部
Boots up the desktop appears but black and explorer doesn't open
The desktop is blank and nothing can be seen no icons or programs and even if I open explorer via task manager it doesn't open I do the F8 repair trick but it says bad hard disk.
Is it fixable. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Dear Zayn Orya,
No, you cannot use it internally, but you can use it as an external hard disk. If you don't see the Dell logo when you boot up, it may be a problem with the BIOS. To fix the BIOS, you will need to replace it from the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zayn orya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 22
