跳转到主内容
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
Ps1 problems with motherboard
My ps1 scph-9002 has a problem with motherboad, it turns on but no video output, no audio or any spinning. Everything is connected.Should i replace the motherboard or try to fix it? Previous user had istalled modchip, so problem could be there also
Also problem is not caused by tv or video output cable
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Have you check if the Av output are damaged?
完成的
Nothing is turning on, av output and motherboard looks fine
完成的
添加一条评论
1个答案
Make sure your PSU cables are connected, and check its voltage with a DMM if you’re sure it is properly connected to the board. It’s more likely to be the board’s power supply if nothing is happening on the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Valtsu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 180
