跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Battery turn off at 30 % charge
Hello,
I just bought a Iphone 3gs and my Problem is that if the battery reaches a level around 30% , the phone just turns off . The only way to get it back running is to charge it up , so that is has more then 30%. Can you tell me how to fix the problem please ?? fyi i dont have the phone jailbreaked or anything , i just bought it on ebay und received it reseted without any programs on it.
yours sincerly
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
done ;) thanks again !
完成的
添加一条评论
1个答案
已选择的解决方案
Try replacing the battery and if that doesn't work replace the logic board.
iPhone 3GS Battery图片
产品
iPhone 3GS Battery
$14.99
这个答案有帮助吗?
得分 1
9条评论:
+...I would definitely start with the battery. After that there are a few more things you can try before you start replacing a logic board....
完成的
ok thanks but why do you think its the logic board ?? the phone just runs fine and its far too expensive to exchange a logic board on a 3gs i just paid 214 euro for mine
完成的
Try replacing the battery first and that will probably fix it.
完成的
ok i just bought this one :
http://www.ebay.de/itm/120818059443?ssPa...
hope it will work
完成的
It should work.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Dominic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,097
