跳转到主内容
How to enable Advance bios in HP Omen 15 (2020)
How can i enable advance bios settings in Hp omen 15 laptops ?
Need battery optimiser settings to set battery to charge to 85%….current at latest bios version but only seeing adaptive battery setting enable or disable (enabling it still lets my laptop to charge to 100%)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi Samarth,
HP will sometimes lock the advanced BIOS if they feel that anymore adjustments would do your system harm. I did find the steps below to help you confirm if this is the case with your system.
To Access Advanced BIOS Settings in HP
  1. Restart your Computer. Stop whatever you are doing.
  2. Enter BIOS Settings. Press the Esc key repeatedly until the Startup menu opens.
  3. Power Off/ Restart your Computer. Power off or restart your computer again, and this time press F9.
  4. Press F10 and Get the Advanced Tab.
If this still does not work then your Advanced BIOS is locked and according an HP forum, there’s no way yo unlock it.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samarth 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 171
过去 30 天: 864
总计 11,886
