跳转到主内容
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 个问题 查看全部
问题已关闭
Why is my Pismo's display dim?
I have two project Pismo's that I recently brought to working condition. One of the two has a somewhat dimmer (less bright) display than the other, even though the brightness is turned up all the way on both machines. Both have 500MHz processors.
Is the florescent backlight just getting old and worn out? Or, could it be another issue (the inverter)?
Thanks,
Randy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the inverter goes you will barely be able to see the screen. The dimmer one may just be dealing with old age and starting to dim.
这个答案有帮助吗?
得分 3
1条评论:
Thanks Mayer, That was my gut feeling. I had not noticed something like this before. Two identical machines sitting side by side can really give you some perspective.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 412
