跳转到主内容
The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
81 个问题 查看全部
phone doesn't connect to WiFi network with more than 2 m distance.
Hi
My phone doesn't connect to WiFi network with more than 2 m distance. I have to be in the same room as the WiFi.
Another thing, my phone requires to be in close physical contact with the device whenever I'm connected to a device that uses bluetooth like wireless earphones or speaker.
Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @gregk4338
Seems like there may be a problem with the WiFi/BT antenna (loose/damaged etc - they both use the same one) in the phone. If the antenna/antenna connection appears to be OK it may be a systemboard problem
Here is a composite image taken from a teardown video showing the antenna and also the WiFi/BT troubleshooting flow chart taken from the service manual, that may help.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
GreG K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 39
