跳转到主内容
A 20" monitor released in March 2012 by Acer, model S200HL
7 个问题 查看全部
Help! My monitor has a white filter over it and I can't get it off
I powered my laptop on and the monitor that it's connected to has a black dead spot on a portion of the screen. While I load up a game, the screen now glitches and it the screen is color inverted and washed with a white filter I can't get rid of.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @alberteinst8428,
White filter sounds like the Contrast setting is adjusted too high.
Have you tried a different video cable, vga or DVI (you didn't specify what type of connection)?
Have you tried using a different monitor, just to prove that the problem is in the monitor and not the laptop?
If you've tried another video cable or even a different input type and it still fails, but it is OK when using a different monitor, it may be simpler to replace the mainboard in the monitor than trying to fix it.
Search online for Acer S200HL mainboard or 3520-0052-0150 to find suppliers that suit you best.
Here's the ifixit Acer S200HL LCD Monitor Motherboard Replacement guide that may help.
If you're interested here's a link that although your monitor doesn't have the same symptoms, shows some components e.g. capacitors (check for domed or leaking), that may affect the operation. Worth looking at first perhaps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Einstien 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 146
