跳转到主内容
A general-purpose audio device that transmits low audio frequencies to your ears.
22 个问题 查看全部
Sparks forming inside subwoofer when plugged in .now it's not turning
When I plugged my subwoofers on . I saw sparks and crackling noise inside the subwoofer through the air out hole . And now it's not turning on . I don't know what to do . Somebody please help. I tried different sockets . But no use
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi
Is the sparks coming from the subwoofer itself or is it coming from a driver board inside the case?
完成的
添加一条评论
1个答案
最有帮助的答案
@androtechm33260 sounds like you are having a power supply in your subwoofer that had a catastrophic failure. you have not told us the make and model of the subwoofer. At this point, the only thing you can do is to unplug it, stop trying to use ist and disassemble it. Lets see which components when up in smoke. I would thing by sparks etc. that this is an MOSFET or the Bridge Rectifier, but it is all a guess until we can see what happened. Post as many pictures as needed, to show your boards etc. Those pictures have to be large and clear so we can at least try and help you to fix your subwoofer.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
adwaithabhirami59 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 57
