跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
Doubting if the MBP screws are Phillips, JIS or Frearson
Hi
I'm going to open my MBP because part of the screen does not look, sometimes is black, other times it flashes. Sometimes even display properly.
I think is the LVDS cable.
But I have to be sure what kind of screws are.
The guide says I need Phillips #00 screwdriver, but they didn't seem it. Big image MBP Screw (Steep 9, LCD Replacement)
I think is JIS (Japanese Industrial Standard) or Reed and Prince (also called Frearson)
Phillips no always is phillips
Phillips Screw head
Phillips vs Frearson
Phillips vs JIS
iFixit sells JIS Driver set
It said:
"JIS screws are not designed to "cam-out" or strip the head when overtightened like a Phillips screw, and can be damaged if a Phillips driver is used. JIS drivers can be used in both JIS and Phillips screws with no damage"
What do you think?
JIS Driver Set图片
产品
JIS Driver Set
$19.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I don't really care what type of screw head is on the MacPro. I need to remove the screws to replace screen and I just want to know where to go to get a driver that works. I bought the set of drivers recommended for screen removal /replacement and none in the set are small enough. I just want someone to tell me what will work and where can I get one, i.e., Rat Shack, etc.. Any ideas?
完成的
添加一条评论
1个答案
已选择的解决方案
This is very nice information and I may order a set of the JIS drivers but have never needed them when working on a Mac. What exactly is your question?
这个答案有帮助吗?
得分 4
4条评论:
Hi, thanks for your reply.
I want to know what kind of screws has the MacBook Pro.
I have to buy screwdrivers to open my MacBook Pro, so I want to buy the correct screwdrivers.
If screw isn't phillips, and I use a phillips screwdriver will most probably I will open the MBP, but it may damage the screw head.
Have you had any problems opening Mac?
Did damaged the screws head?
Thanks!
P.S: Other photo: http://i280.photobucket.com/albums/kk182...
完成的
I've opened a lot of Mac Books. The main problem on some has been with the Pentalobe screws and not having a 000.
完成的
Ok, may be you are right and you didn't have problems, but i am still thinking that screws are not phillips.
What do you think?
完成的
I agree with Mayer -- the problem most often is is just not having a small enough screwdriver. Whether or not they are technically phillips, I've never had a problem removing those screws with a phillips screwdriver. If these screws required a different type of screwdriver, we would have all discovered that years ago. Interesting information though, and I would be curious to try the JIS drivers.
完成的
添加一条评论
添加你的答案
OceanicSix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,590
