跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
20GB logic board for 40Gb iPod?
Is the logic board HD size related? Just replaced battery after 6 years. Does not show up in iTunes. Overnight charge results in 1/4 charged indication. Suspect I have a bad logic board. 20GB Logic boards are available...how does the board relate to HDD size, or is that a misnomer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
jimjarvis, you can use that logic board. It is not depending on the HDD size, the only thing to be careful of is that you use a board for a 4th generation, and not for an iPod photo. Even so some people call it a 4th gen as well. Those logic boards differ in the mounting screw pattern and have different stand-offs. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jimjarvis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 846
