跳转到主内容
针对近期推出的Mac笔记本电脑以及台式机的完全拆卸和组装指南。
42750 个问题 查看全部
问题已关闭
does not power up
My mac just shows a question mark when we power up what might of happen to my mac?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Is this issue resolved?
完成的
添加一条评论
1个答案
已选择的解决方案
This usually means the the computer is unable to find bootable media. If you hold down the Option key (Alt Key) when switching on the Mac do you see any drives appear?
We can verify whether the drive is functioning correctly by following the steps below;
Start your Mac. Put your OS X install disk in the optical drive.
Restart the computer, then hold the C key during startup.
From the Utilities menu, choose Disk Utility. Don't click Continue.
Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
Click the First Aid tab.
Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
After repairing the disk, try to start up normally.
If the repair fails then you will need to replace the drive. If this passes you will need to re-install your OSX from your provided installation disc.
Hope this helps,
Wes
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 227
