跳转到主内容
The slimmer version of the bulkier ThinkPad T420. The T420s is notable for its lower battery life and noisier fan compared to the original T420 laptop.
17 个问题 查看全部
Thinkpad T420s rebooted out of a sudden, freezed and doesn't boot now
I bought a used T420s about 4 years ago. I used it for about 2 years but then the following started:
  1. It rebooted out of a sudden after a while (half an hour to hours).
  2. At startup all lights flash, power and BT LEDs go on for 3 seconds then they go out.
  3. After 5 seconds of darkness it restarts at 2.
And this goes on indefinitely as long as AC is connected, the battery is not empty or removed. Only after leaving it switched off for a certain time (hours? days? I didn't realize a pattern.) it started properly again but the cycle mentioned above happened almost all the time after a while.
Due to this I left it alone for about one and a half a year. Now I tried to reactivate it recently. It started properly but after about an hour the screen froze (a new so far unknown effect) and it didn't accept any mouse or keyboard input.
I always had thought of a heat problem since this started to happen and this time I took the time to open it, clean it and apply fresh thermal paste. To no avail. When switching on the 2.-3. cycle starts immediately, no matter how long (hours to days) I leave it switched off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To fix this issue you can
  • run the Blue Screen troubleshooter
  • Run the sfc/scannow command
  • Launch the DISM tool (Deployment Image Servicing and Management).
  • Run the chkdsk command
  • Use Safe Mode
  • Use Bit Driver Updater to update drivers
这个答案有帮助吗?
得分 0
1条评论:
Really? How am I supposed to do all this when the system doesn't even boot to BIOS (the display remains pitch black at what I described in my Q)?
完成的
添加一条评论
添加你的答案
Geri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 44
