跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
Has white screen, but works OK on external monitor, what's wrong?
Had this issue recently on my 2011 MacBook Pro 15" laptop, screen lights up, but just a white screen, get it connected with external monitor through thunderbolt port, everything shows correctly on the external monitor, but the built in screen still remains white. Thought it might be the video cable between screen and logic board, connection looks good. So, what could be wrong here?
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly the display assembly has failed. There is a small circuit board within it which we call a T-CON. This is not replaceable as it’s part of the LCD panel.
Here’s the needed part 2011 15” MacBook displays and here’s the guide to replace it MacBook Pro 15" Unibody Late 2011 Display Replacement
这个答案有帮助吗?
得分 0
3条评论:
@danj - Hi Dan, so, if the T-Con failed, the screen itself can still be light up? I thought it will be in black screen in this case.
Thanks,
完成的
@lovecd - A white screen is the backlight shining through. The video signal is allowing the light to pass
A black screen could be a dead backlight or the video signal is not letting the light to pass.
LCD screens use a liquid crystal material to flex the light passing through. The concept is where light is combed so the waves are in one direction (polarized) then the other side of the panel the polarization is 90 degrees so the light cant get through, but when the crystals are activated the light is twisted so it can the pass.
完成的
@danj - Thanks Dan!
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 89
