Dryer keeps telling me to check vent but it's squeaky clean!
So I have a Kenmore Elite dryer that keeps ending the cycle after 5-10 minutes, giving me a blinking light on "check vent." I have completely taken apart the exhaust, thoroughly cleaned it, and put it back together. I have also snaked the lint trap and exhaust line forwards and backwards with a spinning brush and shop vac. The vent is clean as can be, so something else is wrong.
Do you know how I can resolve this or at least what to do next for troubleshooting? I was suspecting I might need to replace the motherboard but I would hate to do that just to find out I still have a smaller, cheaper part that is causing the problem.
Hi @willcarson34,
What is the model number of the dryer?
由 jayeff 完成的
@jayeff 796.41983.410
由 Will Carson 完成的
Hi @willcarson34,
Sorry I can't help you with this dryer.
Your dryer is a rebadged LG product made for Kenmore.
Unfortunately, I cannot find a free download for the service sheet (LG part #MHK63813707) which would show you how to run the diagnostic tests to further isolate what the problem is.
The best that I could find is this supplier but you have to pay for it.
You may be able to find a free download or there may be other suppliers that suit you better. Just search for the part number to get results.
由 jayeff 完成的
That's unfortunate...I kinda feel scammed.
Well after playing around with it, it seems to work just fine if I set it to a timed dry with custom settings instead of using a preset...so I'll stick to that for now.
Thanks for trying!
由 Will Carson 完成的
It's probably a fault In a sensor some where in the vent, like a mass flow sensor or something like that. Id just double check that all the wires are seated correctly on the uint before getting professional help.
Bw-100 electrical contact cleaner might be able to spray away the issue.
由 DanielAdvancedDeviceRepair 完成的
显示更多的1条评论
