跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
iPhone fell down and does not switch on, even connected to PC
iPhone fell down from 1 meter height flat on ceramic floor and switched off. Glass is not broken. It does not switch on, and when connected to PC - there are no signs on the screen. What is the possible failed part and if there is anything I can try to fix myself? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
I had the same problem..no reaction whatsoever after it had fallen out of my pocket. . I had the akku /charger/ battery...I am not sure about the correct term for it- replaced and everything worked nicely again. It cost 35€ at a professional store.
完成的
添加一条评论
4个答案
已选择的解决方案
Try this, but you will lose all files etc that you have not backed up. If you are using the same computer it will restore from back up.
1) plug your phone to your computer while running iTunes.
2) perform hard reset by holding home and sleep as you've done before
3) wait for phone to reset Apple logo will go off and come back on... do not release buttons!
4) keep holding until the phone resets one more time and displays the recovery mode screen
5) follow the instruction for 1) restoring from backup or 2) setup as a new iphone
If that will not resolve your problens, it may be time to take it apart and have a look at the obvious parts that could have failed. Unless you have it apart, anything will only be a guess. Start with the battery if you must. Hope this helps, good luck.
这个答案有帮助吗?
得分 5
2条评论:
Hi iphone 6plus fell, the LCD got broken but still in tact then suddenly the phone became very hot. Now it wont turn on or reflect in the computer. Is there still hope? please help
完成的
Thanks man! I had the exact same problem, and thought it is plain dead, but after your instructions it works like a charm, you might saved my iphone :).
完成的
添加一条评论
My iphone fell down from my chest to the ground and now it doesnt turn on, if i connect it to charge, it turns on and resets infinitly, what i can do to fix that?
这个答案有帮助吗?
得分 0
1条评论:
you already solved it?
完成的
添加一条评论
My iphone fell down from my chair to the ground and now it doesnt turn on, if i connect it to charge, it turns on and resets infinitly, what i can do to fix that?
Update (06/21/2018)
这个答案有帮助吗?
得分 0
添加一条评论
My phone fall today morning 13/9/20. It was not opening. Then immediately gone to a local shop they fixed for $15.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Photo Fraiman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 39
总计 31,020
