跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
293 个问题 查看全部
Thermal sensor in hard disk replacement
Hello everybody, i'm sorry for my english, I'll try to be as explicit as possible.
I've an iMac 21.5" emc 2308 and last friday my Hitachi 1 tb Hard Disk "died".
I've bought a western digital 1tb green HD, and the ifix guide for the HD replacement, about "thermal sensor" write down: "During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors". The Hitachi has two pins arranged like this:
xx
but the Western Digital has 8 pins arranged like this:
xxxx
xxxx
I've connected the thermal cable to the set of pins closest to the sata connectors ... in this way:
xxxo
xxxo
Is this correct???
Thanks so much for your answers!!!!!!!!!!!!
Claudio
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
I've fixed it, i've adapted the cable ... it works perfectly!!!!! Thanks!
这个答案有帮助吗?
得分 1
1条评论:
Please tell us what you did and if the fans are racing.
完成的
添加一条评论
You need a Hitachi Hard Drive.
I've got the same trouble.
这个答案有帮助吗?
得分 0
添加一条评论
SSD Fan Control, google it.
That was the solution to my iMac.
这个答案有帮助吗?
得分 0
添加一条评论
If the original poster could add how thery fixed th eproblem i'd be grateful. I have the same problem.
I changed a 500g Seagate to a 1G seagate...and now my fan is running on full..wondering if i need to reverse the cable or simply modify a setting.
Regards;
mac
Update
Thanks Dan.
I opened up the mac again and could not find any cable that I might have missed. I also called seagate ( the 500g i removed was a barracuda 7200...as was Th.e1TB i installed) and they have NO idea that is compatible with mac or if there is a setting that could be adjusted.
Rather than order a cable set and have to go in deeper on the board - i downloaded HDD Fan control....works great.
I appreciate your reply however.
Thanks
mac
这个答案有帮助吗?
得分 0
2条评论:
Depending on the model you have you should find an external sensor mooted on the HD case. If not then you have one that uses the internal sensor. We use this kit from OWC 27" iMac kit. This by-passes the internal sensor in the new HD (if it has one) to an external sensor. This allows you to us any HD. If you got one of the very new HD's that support Apples internal sensor you should be OK.
完成的
The last option is using FanControl which is a software solution. But it does impact the HD's performance slightly as it uses HD's SMART services to read the HD's temp and control the fans speed.
完成的
添加一条评论
添加你的答案
Claudio 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,897
