跳转到主内容
Which is bad, battery or charger
My "greenworks pro" 60 volt lithium battery is not taking a charge, but I I don't know if I need a new battery, or a new charger. Do you know any way to determine this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
try a new charger first
has the charger been exposed to water or is it frayed/ripped anywhere?
完成的
Thnx, timtom. I'm trying to figure this out without having to buy one (that I might not need, if mine is good) to try. Those chargers are kind of expensive...
完成的
No, not apparent physical damage to the charger, and no exposure to water that i know of.
完成的
@tvz62367 hm
does anything else that uses the same port work with the charger?
完成的
@TVZ do you have a multimeter or can you borrow one?
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
@tvz62367 Do you have a charger number? You could use an ammeter and put it in between your charger and your battery and see how many amps it draws. You can do some basic test with your multimeter. Check something like this It tests the same way for your battery as well. Let us know what you find out.
这个答案有帮助吗?
得分 1
添加一条评论
I tested the voltage that the charger is putting out. It's much lower than a similar charger (different brand) that I have. I have ordered a new one. Thnx to all for the suggestions!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TVZ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 140
