跳转到主内容
Repair guides and support for cameras by Blink. Video Home Security Camera with Batteries that Last Up to Two Years. Models: Blink, Blink XT2, Blink Indoor, Blink Outdoor, Blink Mini
4 个问题 查看全部
Outdoor camera full of rain water
My blink outdoor filled up with rain. How can I open it up to dry it out and clean the inside of the lens?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
If this was placed without shielding from rain falling directly on it, it's probably not water proof. Even weather proof devices can collect water and debris. Some devices with replaceable batteries may allow disassembly with screws hidden under labeling. Probing with a small tipped screwdriver pressed onto labeling may reveal a hidden screw hole(s). Others are heat sealed and not meant for repairs.
完成的
添加一条评论
1个答案
I solved this problem with a camera pointed mostly down. While I was not able to open it to clean the moisture out, I did take the back cover off and place it in front of a fan. Which dried it out after 5 hours. As far as keeping it from happening again I just covered the back with Duct tape. Problem solved
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Big Bird 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 40
过去 30 天: 172
总计 430
