Switch Lite headphone jack faulty?
I have a Nintendo Switch Lite which has a weird problem.
The console thinks there are headphones plugged in, even though there aren't any.
I have flooded the headphone jack with contact cleaner and IPA and have inserted and removed a headphone plug several times to try to clear it.
I have also tried all the menu options to mute audio when headphones disconnected, tried formatting/factory resetting and have even transplanted another headphone/card reader board from a donor switch, but it still does the same.
By the way, when I DO plug headphones in, audio can be heard from them.
Anyone have any idea what would cause this?
have you tried a factory reset?
(you can use a micro sd card to back up your data btw)
由 timtom7777 完成的
Yes, as stated in my post, I tried formatting/factory resetting.
由 Matthew Sweet 完成的
