跳转到主内容
加入维修社区 - 创建账户
New screen camera not working
I swapped a screen from a Macbook Pro A2251 and installed it in a MacBook Pro A1708, the screen works as expected but the camera isn't working saying camera not detected in all applications. I have checked all the connections and reseated them. Should this setup work and what connection is for the camera?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@jasonmullan - Where did you purchase it?
完成的
I got it from a friends busted machine
完成的
添加一条评论
1个答案
A2251 refers to a MacBook Pro (13-inch, 2020, Four Thunderbolt 3 ports), and A1708 refers to either the MacBook Pro (13-inch, 2016, Two Thunderbolt 3 Ports) or the MacBook Pro (13-inch, 2017, Two Thunderbolt 3 Ports). The display from the 2020 MBP is not fully compatible with the 2016 and 2017 models. Although the display portion will function, the camera will not. In order to have a working camera you will need to install a fully compatible display. Check this page for further information.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Mullan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 275
