跳转到主内容
The N95 8GB is a revision of the N95, with a larger screen, 8GB of internal flash storage and larger capacity battery.
2 个问题 查看全部
问题已关闭
I can not turn on my nokia n95 8gb phone?
The screen shows the charging battery icon, the number keys lite up when pressed, battery has been charging for several hours, and does not show a full charge. The phone has been dorment for a long time, and im charging it through the usb adapter.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Joe, if your phone was not used for a good while, I would suggest that you change your battery. It is possible that you battery is past the point of its life expectancy and not accepting a charge. Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
joe ur granda ma must have eat the batterey
这个答案有帮助吗?
得分 1
添加一条评论
my nokia n95 is power on after month but it is no power how iam on my mobile self
这个答案有帮助吗?
得分 0
添加一条评论
you should use 12 voltage of any charger to shock the battery of n95 for 8 second because i think it was just drain... if u have more problim you can call me baby,,, 09098016760
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,262
