跳转到主内容
修复你的物品
维修的权力
商店
为众多三星安卓智能手机编撰的修理指南和拆解,无论新旧,包括备受欢迎的盖乐世产品线。
9354 个问题 查看全部
Samsung Galaxy S screen repair?
is this phones screen the same as the sII, or the sII 4g??
can i just change the glass or do i have to change the lcd screen too?? please help...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个回答
已选择的解决方案
Here's how to do it ..http://www.formymobile.co.uk/galaxysdisa..., as E Carson says the 2 screens (touch and display) are joined so you can't separate them. You may find someone who says you can but for me I don't think picking pieces off for 2 days is a successful way to do things. If you are careful and take things slowly I'm sure you will be able to do this repair. You will need to find someone who sells..here or here also on ebay..
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
I would not recommend attempting to repair this phone. Specifically the AMOLED screen is attached to the digitizer by glue. The digitizer/screen is glued into the bezel. No one has succeeded in replacing the screen and Digitizer without breaking the old one into many dangerous sharp pieces. Removing the glue involves heating the device to levels that risk damaging the device, 130C. This has led to speculation that Samsung just replaces defective i9000 devices due to the high cost of labor involved with repair. I really can not explain how much glue is involved.
If however you really want to give it a go, read this forum post:
http://forum.xda-developers.com/showthre...
这个答案有帮助吗?
得分 2
添加一条评论
i found this on youtube:
trick for separate the outer glass and the digitizer
http://www.youtube.com/watch?v=judy-izOm...
这个答案有帮助吗?
得分 1
添加一条评论
Is the GT-i9000 screen the same as a S-i9000? just ordered an s-i9000 replacement screen for a GT-i9000?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave Bloxham 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 14,527
