跳转到主内容
Repair and disassembly information for the Logitech MX Master 2S wireless mouse. Released in 2017 and identified by model numbers M-R0066, 910-005138, 910-005137, or 910-005131.
Right mouse click is not working
Hello,
my right mouse click suddenly stopped working on my MX Master 2s.
I tried following steps without any success:
1) Turned mouse on/off
2) Connected mouse via bluetooth dongle on other computer
3) Switched left/right mouse click via Windows settings
4) Bought a new original mouse click switch (from Omron) and replaced the old switch
-> After all my right mouse click is not working!
-> I now use a wired, old mouse and I have no problem at all with this.
Can you please help me?
Do you think it might be a hardware malfunction on the motherboard?
I mean I even replaced the switch.
Thanks,
Fabian
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Same issue here, is there any kit for solving this in Ifixt?
完成的
添加一条评论
2个答案
最有帮助的答案
Have you checked the top "activator plate", of the mouse that activates the switch uppon depression of the mouse buttons? It sounds like the there may be a gouge in the "activator plate" which prevents the plate from making contact with the switch.
If you do see this I used some hot glue and filled in the gouge on an MX master 3 and its been going strong for a few months now. But you can also use other fillers to get better results.
这个答案有帮助吗?
得分 1
添加一条评论
Hello Zach,
thank for your help. Unfortunately this did not help. The "activator plate" has full contact to the switch. I even demounted the upper shell of the mouse and clicked on the switcc directly with my fingers. The right mouse click gives a nice snappy accoustical feedback, yes, but there is no response on my computer. In my opinion there must be a hardware malfunction on the motherboard.
Well I don't know what to now. Seems to be broken, unrepairable.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mr. Mouse 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 39
过去 30 天: 135
总计 3,118
