跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
258 个问题 查看全部
Why is my screen displaying a black screen and question mark sign?
Why is my MacBook Pro showing black screen with a question mark sign in the middle?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
This usually indicates that it either doesn't see it's internal drive, or doesn't have one installed.
However if it doesn't recognize a present drive, repair is going to be extremely difficult because the ssd is soldered onto the logic board.
Try starting up into recovery by pressing the power button and holding Option-Command-R until a globe appears.
This should allow you to get access to some utilities to check your drive.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your comment @maxmc. I’ve but it can find the drive
完成的
添加一条评论
最有帮助的答案
@nmjz5vizxwsgwzm - Time to visit an independent Mac repair shop or visit an Apple Store.
Your system needs deeper repairs.
这个答案有帮助吗?
得分 1
添加一条评论
Well you can try the following methods to fix the issue you are facing:
  1. Press and hold the power button on your Mac for up to 10 seconds, until your Mac turns off.
  2. Use Disk Utility to repair your startup disk.
  3. If Disk Utility found no errors or repaired all errors, reinstall macOS.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your help @gtip. I have tried this process but it can’t find the disk where I want to install the macOS.
完成的
添加一条评论
Try this. Shut down your Mac.
Press the start button and IMMEDIATELY press the following 4 keys until you see a startup screen. (You may want to practice your finger positions before you begin because this can be tricky and you have to move fast.)
OPTION + COMMAND + SHIFT + R
You must hold all 4 keys down until the startup screen appears. If a finger slips off you'll need to start over.
You should be presented with an option to restore over the internet. Select your internal drive (if it's shown) and follow the onscreen prompts to reinstall the version of MacOS that came with your computer. You will need a network connection for this to work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kome75y2k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 48
