跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Think I've been sold a dead iPhone 3G... - Logic Boards?
Recently bought a iPhone for the missus that she was really happy with. It was a 2g iPhone that we got really cheap becuase the guy didnt know how to restore it.
I restored it - and it works - great.
I ended up then buying a 3g one for myself. The guy explained that it boots to the apple logo and you can get it to display the ITunes logo ready to sync.
What he didnt say is it will only do this on mains power. Once you remove the power cable it instantly dies.
First I thought battery, but no - it doesnt show the charge logo so it cant be a poor battery not holding charge can it? otherwise it would have the red battery logo all the time surely?
so I decided it must be the charging dock.
I ordered the parts, they arrived and I replaced the dock. interestingly enough - while i was inside I noticed the water labels had been tripped on both the dock and the lower part of the logic board. (oh ****).
ever the optimistic, I replaced - cleaned what I could with nail polish remover and rebuilt. I also checked for volts across the PCB battery terminals - which indicated 1.5v. - so I assume the battery has charge?
long story short - (or not) I'm not fixed.
still does the same think and im more ££ down.
your thoughts? new logic board? - does anyone know where I can get them cheap?
should I cut my losses?
no other water sensors are tripped - i.e. top PCB / headphone jack and so on.
tell me its not dead!!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
It sounds like the battery is below the charging threshold. A LIon battery needs to be around 3.7V for the charger to kick in. We usually dismantle the phone and connect the battery directly to a 4.2V source with multimeter attached to see when it reaches 3.7V, usually it takes only a few mins to get to 3.7V. Once this is done, you can connect the USB cable and charge normally.
这个答案有帮助吗?
得分 1
添加一条评论
Hey tetsuo,
thanks for your help - after putting the board into another phone it turned out to be the battery!
Despite the water damage the phone worked a treat!
I just have one now that doesn't connect with the computer. It charges in computer / in wall charger etc and I can put it into DFU easily it just doesn't prompt windows...
Tried different connector docks/ USB wires etc..
Help!
Thanks again
neil
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 2,477
