Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Its mine from new,yes i have dropped it but only from a low height and this was a good few months ago,i do get signal sometimes and 3g but its intermitant,any thoughts i was thinking its the gps antenna.
does it happens when you walk or stand still? if it is when you walk then you should replace the component that switch between Athena's and not the phone Athena's if it is when you are standing still then you should replace the phone Athena's
is the phone new to you? what history do you have for the phone? any drops/damage?
由 pollytintop 完成的
由 Russ 完成的
