跳转到主内容
The LG VX5200 is a CDMA flip phone with an external antenna, 32 MB of onboard memory, and a 1000 mAh Li-ion battery.
SIM card slot location?
Where is the slot for a SIM card located on my LG VX5200? Is there one? If not, what do I need to do to make the phone able to recei
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
If I don't see were to place my sim card what should I do to receive calls
完成的
Per my previous email. RTFM. See above.
完成的
@hassangabr19854 just as explained in the answers below :-) there isn't one.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Tess,
That particular phone was made pretty much exclusively for Verizon, and didn't come with a SIM card slot, since it only works on Verizon's CDMA network. It wasn't until the iPhone 5 that iPhones on Verizon started using SIM cards, and it's about that time frame that other phones that ran on Verizon also started using SIM cards.
Unfortunately, the phone does not support 4G networks so Verizon is not going to let you activate it on their network; they've phased out their older 2G technology and 3G is on its way out as well. So unless you can find another carrier that still supports the CDMA network, that phone is pretty much going to be a pretty brick.
这个答案有帮助吗?
得分 1
添加一条评论
@tess85230 is a CDMA phone that does not use a SIM card. You will need a provider (used to be Verizon) that still supports your phone to see what needs to be done to get it activated. Check this Wiki for more info on your phone. LG VX5200 Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tess 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 40
总计 607
