跳转到主内容
加入维修社区 - 创建账户
Kia Optima 是起亚汽车(Kia Motors)自 2000 年起生产的一款中型轿车,在全球范围内以多种名称销售。第一代车型(2001-2005 年)通常被称为 Optima,不过从 2002 年起在欧洲和加拿大开始销售时,该车型的名称为 Kia Magentis。
Why does my mama's 2005 Kia Optima act like it's not getting gas?
My husband just did a oil change, and oil treatment on my mama's 2005 Kia Optima, and now when we start the car it idles very roughly, and when we put it in gear it almost dies. What could be causing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
13条评论
I forgot to mention that a mechanic told us to check the catalytic converter. So my husband took the exhaust loose from the manifold, and it still runs like crap. Any ideas?
由完成的
Did it run okay before the oil change?
由完成的
Not really. The idle was off a little, it has a vibration when idling or in gear, and other minor issues.
由完成的
He has now taken the EGR valve off (which is black inside), and the inside of the intake is black as well.
由完成的
A car needs 4 things to run: Air, fuel, spark and compression. If any one of these are missing the car won't run well or at all. My suggestion would be to check the spark plugs to make sure they are sparking. This can be done by removing the spark plug, contacting it to a metal engine component and turning the engine over briefly (Do not let it run for any extended period of time like this). Be sure to wear some nice thick gloves so you don't get shocked. Fuel should also spray out of the hole that the spark plug was in. Check all your cylinders and be sure each one is getting fuel and spark. Let us know what you find.
由完成的
显示更多的8条评论
添加一条评论
4个答案
已选择的解决方案
Okay, so you changed the spark plugs, check the face of the plugs and see what they look like. They should not be black with soot. Also change the wires since it is possible that they are cracked. If no result from that, it is possible that the Camshaft position sensor is not working right, as well as the Crankshaft position sensor. Clean the Idle air control valve, or replace it if necessary. The only other thing I can think of right now would be to clean the Mass air flow meter and definitely check the coils.
这个答案有帮助吗?
得分 1
2条评论:
Thank you so much for your input. As I stated previously, the two spark plugs w/o coil packs were black, and the two with coil packs aren't. We have got the coil packs and wires ordered, and have to go pick them up tomorrow. I will let you know if they works, and see if you can offer any other suggestions. We also changed the crankshaft positioning sensor after we had to change the timing belt about 6 months ago.
由完成的
Amy Geeter, thank you for accepting my answer. Right now it looks like the coil, so let us know if it works for you. If need should be, check my email in my profile (click on the avatar, my smiley face) and I might find the service manual for you :-)
由完成的
添加一条评论
Same problem with our 2005 optima.. changed input/output sensors, both coil packs, both coil boots, spark plugs & wires, throddle position sensor. Still running like crap
这个答案有帮助吗?
得分 1
添加一条评论
Check your fuel filter
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem. Check the input and output tranismission speed sensor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amy Geeter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 6,334
