How to repair my psp when can't on power
my psp 1000 can't on and when my battery full also can't working....
Look at the DC port on the PSP. Does it have the little metal pin sticking out of the middle? It is also possible that the switch on the power board may no longer work. Pick any of the guides listed on here PSP 1000 and open the PSP up and see if you can hold the power board still, plug it in and try flipping the black switch to see if it'll turn on that way. Of course there is also the possibility that your power fuse is blown and that you have an interrupted circuit. check on here for much more info about that. Hope this helps, good luck.
这个答案有帮助吗?
i will try it....thank for teching....
but me is 3006 modal...can help??
ginz.. this is the guide for you PSP 300x, I'm not sure that the fuse is in the same spot..If you need further help then please start a new question.
where the 300x fuse and i think board spot...
uuuum...Does this work on Non-Sony PSP...cause my PSP is not sony
I had seen on Youtube if you repeatedly push up the power button, it might turn on. Worth trying
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 39
过去 30 天: 206
总计 34,476
3条评论
I have the same problem too!!
I checked the batery, the power is connected to the motherboard.
由 Abo Muhmmd 完成的
How do I do that
that
由 lil king 完成的
i have problem with my psp start and l buttom
由 anmol rekta 完成的
