跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Won't turn on
Hello you guys, so i got a MB from my brother and he told me its been off for two years due to him losing the charger. Well I bought a new one and it was charging and still does but as soon as i hit the power button it sounds like its trying to turn on but than turns off right away after hiting the power button. Just trying to see what could be the problem. I have tried every way to get it to start changed the RAM and battery I even sprayed Duster spray on it to clean it and it still doing the same. Just need help please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Can you take a video of it trying to startup?
Also Is it a 2008, 2009, 2010, 2011, or 2012?
完成的
添加一条评论
1个答案
Being in off for so long and the systems age it likely needs a new battery as well.
Let’s see if we can at least get a better idea if that’s all it’s needed.
Follow this guide to remove the battery MacBook Unibody Model A1278 Battery Replacement with the battery removed press and hold the power button to fully discharge the logic board. Now plug in the MagSafe charger did the system start up this time without the battery?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christina Copeland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 100
